- LDO Trident 300
- Galileo
Hello everyone,
I've read a few posts here regarding POM nut wear on the tridents. I'm having a similar issue with my rear z stepper on a LDO 300 trident. I'm rebuilding the printer for the 3rd time, new printed parts, etc. While doing so I've noticed the rear stepper mount actually tilts slightly forward, especially when secured with the 2 bottom front facing fasteners. I have a 3 - 4mm difference from the centre of the leadsrew to the face of the rear vertical extrusion when measured at the bottom and also the top. Basically, the leadscrew tilts forward at the top by ~3mm.
What made me rebuild was due to the bed suddenly dropping at the back as the thread had been totally worn down. I do have my pom nuts adjusted to the point where they can easily move horizontally.
My frame is nice an square, and the rear bottom extrusion which the motor mount is attached to also is square. I'm wondering if the extrusion is somehow twisted but this seems unlikely.
Any thoughts on a solution would be appreciated. I could just not use the bottom fasteners, which brings the leadscrew back a little and hope it's enough.
Thanks!
PS. Actually, I rebuilt to add a few mods and such, but the POM nut issue is what got me started!
Thanks!
