Hello everyone
I'm new here but have been looking into Voron printers for a while as I want an upgrade to my Hemera modified Prusa Mk3. I love the design of the Trident but I also want an IDEX machine so I've become interested in Eddietheengineer's Tridex design but before I go fully into buying everything I just want to see if anyone can answer a few questions on this.
Clearly the Tridex needs more effort to build than the Trident and I have no concerns at all about the mechanical build differences, however I am a little worried about the firmware side of things. Has anyone built one of these and can tell me how complex the firmware changes are?
My main question is around the firmware/software/calibration. Is it a matter of running existing written macros then adjusting values in the firmware -this is fine. Or would I need to edit firmware and recompile it? When I did my Hemera mod for my Prusa I had to edit the firmware directly and recompile it which was hard going and although I have a working solution I could never get it to work properly with the MMU2.
Then if I was to modify the Z sensor with something like the OptoTAPsensor, how complex would the firmware changes be to make it run with two OptoTAP sensors?
Then what about CAN bus mods? Can Klipper work with two CAN bus print heads?
Secondly, clearly having two extruders will reduce the print area but I've also read about wipe brushes etc taking up more space -can anyone tell me what build plate size would work if I used a Trident 350 frame? Does the IDEX only reduce the X axis or do I loose Y axis too for wipe brushes etc?
So I'd love to go for a Tridex build but I don't want to spend all the money and build time just to find I can't get through the last few hurdles
Any comments or thoughts would be welcome.
Thanks
Thanks
