Hi together,
I am thinking about building a Voron V2 to backup my old printer.
This would be my 3rd DYI printer. I have never had an out of the box printer and would only buy a resin printer. The rest can be built well in my opinion. I started with a DIY printer from a German forum in 2017 and then cannibalized it in 2018 and converted it to a HEVO (Hypercube Evolution).
My HEVO is hardly a HEVO anymore and has the following mods:
- Orbiter V2
- Volcano with 0.4mm nozzle or 0.8mm nozzle
- Belt drive Z-axis with two rods each
- Duet3 WIFI
- BL Touch
- Heated, finely milled aluminum plate with textured PEI
I'm currently considering whether to convert to CANBUS to make the hotend lighter. I print PETG at 100mm/s and 0.2mm layer height, which is a pretty good print.
What would appeal to me now would be
- Canbus
- Larger build room (at the moment 230x230mm)
- 24V
- Linear rails
- Tool changer
- Closed installation space with filter for ABS
Now I could convert the HEVO. However, I still have the risk that if something breaks, the printer will stop and I will need parts from someone else. Instead of converting the HEVO, the idea would be to leave it as it is and build a Voron without any time pressure. I just think that the Voron will then become my main printer and the HEVO might just stand around at some point. Or I might like the linear rails and Canbus so much that I convert the HEVO too and then have two very good printers standing around.
I usually just print technical pars I need for projects. I do not print figures or commercial orders.
How would you handle that?
- Orbiter V2
- Duet3 WIFI
- BL Touch
- Canbus
- 24V
- Linear rails
- Tool changer
