flyingbrick
- Voron 0.2
- Other
- Other
Hello everyone,
I bought a Formbot voron 0.2 kit and after partially assembling the MiniSB, when I try to do the filament gear check (feed filament through the gears and see if it creates light teeth marks) it will not feed for the life of me.
To be clear, there is NO stepper attached, just the motor plate.
The tension screw is screwed all the way and the antisquish thingamajig is backed all the way in.
I have reprinted the guidler and disassembled and reassembled the extruder multiple times and I am almost at the end of my wits.
Thanks!
Thanks!
