desmond007
After happily building and frequently using my Voron 2.4 R2 350 i have been vexed with this layer issue.
For example, when printing a 20x20x30 cube i get squished layers from 5mm to 12mm. This means that the layer height in this range is much smaller than sliced (.2mm) and the side bulge out. Strangely the print is fine above 12 mm.
Setup : Klipper/Mailsail. Slicing with Superslice with Ellis profiles.
Thing tried:
Things i am going to try next
Thing tried:
- Different hotends - 0.4 Dragon / DropEffect XG
- Diffent filaments - same with ABS, PC, PLA
- Different Tension on Filament Feed gears
- Different Tension on Z belts looser and tighter
- Replaced Z belts
- Inspected all idlers and belt for wear, debris
- Different print speeds
- Different layer heights.
- Upgraded superslicer / klipper / mailsail, etc
- Vase mode seams ok but may just not be as noticeable.
- Loop belts for the z drive motors
- New idlers
- New Z motors
