Hi, I am building A self-sourced voron trident (400x400x500 build), with a BTT Octopus PRO v1.1.
Everything is going great for now, toolhead is doing what it's supposed to etc.
Only I am now configuring the 3 Z-Steppers and they are doing completely different things.
Here is Z-stepper config sample I currently have :
- front left is noisy and when buzzed only moves down
- Rear functions exactly as expected
- front right doesn't move at all
# Z Stepper Settings
## Z0 Stepper - Front Left
## Connected to MOTOR_2_1
## Endstop connected to DIAG_2
[stepper_z]
step_pin: PF11
dir_pin: PG3
enable_pin: !PG5
# Rotation Distance for TR8x8 = 8, TR8x4 = 4, TR8x2 = 2
rotation_distance: 8
microsteps: 32
endstop_pin: PG10
## Z-position of nozzle (in mm) to z-endstop trigger point relative to print surface (Z0)
## (+) value = endstop above Z0, (-) value = endstop below
## Increasing position_endstop brings nozzle closer to the bed
## After you run Z_ENDSTOP_CALIBRATE, position_endstop will be stored at the very end of your config
position_endstop: -0.5
## All builds use same Max Z
position_max: 500
position_min: -2.5
homing_speed: 8.0 # Leadscrews are slower than 2.4, 10 is a recommended max.
second_homing_speed: 3
homing_retract_dist: 3
[tmc2209 stepper_z]
uart_pin: PC6
interpolate: False
run_current: 0.6
sense_resistor: 0.110
stealthchop_threshold: 0
## Z1 Stepper - Rear Center
## Connected to MOTOR_3
[stepper_z1]
step_pin: PG4
dir_pin: PC1
## Octopus 1.0 & 1.1. Octopus PRO 1.0
#enable_pin: !PA0
## Octopus PRO 1.1
enable_pin: !PA2
microsteps: 32
[tmc2209 stepper_z1]
uart_pin: PC7
interpolate: False
run_current: 0.6
## Z2 Stepper - Front Right
## Connected to MOTOR_4
[stepper_z2]
step_pin: PF9
dir_pin: PF10
enable_pin: !PG2
microsteps: 32
[tmc2209 stepper_z2]
uart_pin: PF2
interpolate: False
run_current: 0.6
