cabinfourus
- Voron 2.4
- Clockwork 2
I am finishing up my first Voron 2.4 build. While going through the initial startup, I noticed my hot end Neo pixels stopped working. I thought maybe the wiring had come loose or maybe a connector, but everything checked out okay. I went ahead with the start-up and when I came to the level sensor part, my level sensor always read open, and the red light was on. While double-checking my print configuration files, I did a firmware reset and everything started working again. I homed my X axis, then the Y axis, and the Neo pixels went off, and the level sensor stopped working. This only happens when I home the X and Y axis, and it triggers the end stops.
My end stop setup is the typical mechanical type, and my level sensor is on the Octopus 1.1 PG15 pin with the bat 85 diodes. My diode is installed correctly, with the black line towards the hot end.
This must be tied to the end stop configuration somehow, but for the life of me, I can't figure it out.
Thanks for any help,
John
John
