- Voron 2.4R
- Other
- Afterburner
Good morning, as the title suggests I've got an odd issue.
If we SWAP motors A/B on the board so that they are wired with A to motor 0 and B to motor 1 the x and y home and move in the correct direction. However the two axis are inverted this way (X is front to back while y is now right to left)
However if we swap the wiring back to match the original, no matter what i change on the direction pin either one or the other will be backwards no matter what we change.
I've attached the config file we've started with - all axis move in the right direction when doing a buzz as well. So it's just odd it's only during homing but during buzz all works as expected.
