MichaelOToole
It all started with a broken clockwork2 latch...
Recently latch part broke, so I replaced it with the reinforced version but could not get the latch to click in place/close.
I purchased the aluminum version (which comes in 3 parts) I replaced broken part, again it would not close...
Left with no option, I then took the assembly apart only to find another piece of the original broken latch, obviously it was the culprit.
I should point out I examined the broken latch pieces and they pretty much matched the first strengthened latch I printed.
Anyway, I removed it and reassembled using the 3 net aluminum parts... that fixed the main issue but now probe calibration is doing my head in.
Z-Offset Question
With the new part in place, I tried several print all of which failed on the first layer... Z offset must be wrong?
I ran probe calibration (several times), the results were pretty constant about -0.45, I edited my config (in my case that's probe.cfg) using this figure but still no luck...
I made adjustments starting at -0.4, which of course failed, then tried -0.35 which was looking promising but corner of print was messed up, so tried -0.33 and it was almost perfect, at least two print succeeded, a bit long winded but it might prove useful to someone down the road...
All I need to know now is why was the probe calibration so far away, did something change during an update or have I made mistakes?
Z-Offset Question
