kharrisma
I'm installing a Nitehawk SB USB toolboard in my Stealthburner, and both fan sockets have three leads: plus, ground, and tach.   My current 5015 has only two leads; I'm sure it'll work without the tach, but I'd rather have one with it given that the board has the capability.  I've found several five-volt versions, but no 24-volters.  The Nitehawk 36 is able to switch voltage between 5 volts and 12 (?) volts, but this ability is absent in the Nitehawk SB (as far as I can tell.).  Anyone here using three-lead 24 volt 5015's, and if so, where did you find 'em??  Thanks!
