- Voron v1.8/ Trident
- Clockwork 1
- Afterburner
Hi, Im planning on building Voron v1.8. The bed on the BOM is 8mm thick. It is hard to find aluminum sheet with that kind of thickness, even if I do, it costs much more.
The available I saw is a 6mm thick, can I replace the bed with this? The only thing that I think I need to change from the BOM together with the aluminum plate is the 5x30mm rod for the z end (or I can change the stl for this to accommodate 2mm loss in height).
Another option is to buy 6mm and 2mm plate and stack them up together (yes, 6mm and 2mm plates are cheaper than 8mm plate). Im worried about the heating issue with this method.
