Abs not working well on overhangs
Good morning I have a problem. With not 2.4 r2 printing abs on overhangs using orca and the calabration abs is esun abs+ bed temp 105 degc nozzel temp 265degc tried 280deg c some with parts fan on and off using the flow test printed will from 15 to 30 towards the end of the second test 30 to 45 not so good but that is ok hot end is a rapido 2 uhf and extruder galleleo 2 bed I sticking well see pics below input welcome
What is you fan speed?
And how fast is your actually print speed at the overhangs? Maybe show the print speed view.
Here you go sorry about the delay
Can you take a screenshot of the speed view after slicing? The one on the "Preview" tab, with color sheme Speed.
That would make it much easier.
Yes, the speeds tab is important. IMHO Orca defaults have stupid fast speeds & needs to be slowed down. I question where they got those values from & if they even tested them.
Can't see shit.
On windows you can press Win + Shift + S to take an screenshot of an area. And then ctrl C to copy and Ctrl V to paste it in here.
Mhh, seem like the overhangs are at 10 mm/s, so that should be fine.
And the fan is actually working? I mean it does blow air?
I'm somewhat out of ideas.
I can see that ~something~ is being printed at 392 mm/s, which can be quite fast. As a test you could set the maximum speed to .. 120 .. just to test it. But I doubt that is the issue.
