covertaero
Trying to get past this ADC error. All research says extruder thermistor. Wondering if there is a better way to test. I have pulled the thermistor from the hot end and am trying to plug it into the Spider port directly.
Can't find clear config info for this thermistor. It is the one that came with the E3D stealthburner that I have. 3mm dia and about 12mm long copper barrel to fit the heater block.
Thermistor appears to be a: HT-NTC100K
Config file attached.
Printer is fully built and wired Voron 2.4 350... Has hartk hot end board but I am trying to bypass that to check thermistor. Bed heater thermistor is plugged in directly. Understand if this is configured and working properly that I should see about room temp on both. Can't get the dashboard to come up to find out.
