2) I hate to be the bearer of bad news, but if you bought a random sheet from Amazon, there is a significant possibility that it’s something other than PEI. Lots of other plastics work fine for a while, but then start to have significant problems. There is good news, however! If it is “fake PEI”, then it should still work OK if you do some prep work with it. The sandpaper scrub that I described should give it a nice, fresh surface that should work better. Try that as a first step, but if it’s still having issues, getting genuine PEI sheets from a reputable seller is highly recommended. I, personally, use the black Honeybadger PEI textured sheets. Hector from Fabreeko offered me a sample sheet to try, and I’ve been using it for about 6 months with zero issues. There are plenty of others that work great, but I can personally vouch for the Fabreeko sheets being very good.Not formally no. I've had that filament for at least 6 months. It sits in a cabinet filled with my collected silica packets.
- I'll have to google techniques to dry it
- Amazon. It worked perfectly before, I took a few months break from printing and now i'm having problems.
- I do need to go to the hardware store, I'll pick some up.
- Good point. I'll try that. Which do you think is best, paper towels or "shop towels" (the blue, fabric-like paper towels)?
4) I have a roll of the blue shop towels, but I literally only use them because I bought a roll a long time ago and haven’t used them up. Regular paper towels should be fine. Just avoid the super cheap ones that fall apart when you look at the funny.
Good luck!
