Bed Mesh doesn't lift enough during x/y travel
dgotc
Hello All,
I have 300mm 2.4r2 with klicky. All of the z calibrate and gantry leveling is working. The problem I'm having is while trying to populate a bed mesh the probe keeps dragging while traveling between sample points. I've tried adjusting various parameters but nothing makes a difference when it travels horizontally. There doesn't seem to be a klicky variable for this. Any help is appreciated. Thanks.
The error message is "Probe triggered prior to movement" which is obvious when looking at it.
dgotc
Hello All,
I figured it out with a little help on the discord. In bed_mesh.cfg I increased the value of horizontal_move_z from default of 5 to 10.
Dave
Staff member
Voron Owner
Glad that you found the solution and were able to fix it. Thanks for documenting it for the next person who runs into the issue!
