- VORON 2.4
- Extruder Type
- Galileo
- Cooling Type
- Stealthburner
Hi. I am building a 2.4 with MANTA MP8 V2.0 and TMC2240 having the reading of the temperature of the steppers. I have seen that driving the Z motors at the same current there is a gradual change in temperature. I understand the driving current is not properly distributed with some internal V or A drop in between. With X Y motors the same happens but smaller difference since only two motors.
Anyone experienced that and knows the root of the issue?
Belts are properly balanced and I am providing readings with motors in standby.
The actual steppers config as follows:
[stepper_z]
step_pin: PB8
dir_pin: PB7
enable_pin: !PE0
microsteps: 16
rotation_distance: 40
gear_ratio: 80:16
endstop_pin: probe:z_virtual_endstop
position_max: 340
position_min: -5.0
homing_speed: 10
second_homing_speed: 3
homing_retract_dist: 3
[tmc2240 stepper_z]
cs_pin: PB9
spi_software_sclk_pin: PG8
spi_software_mosi_pin: PG6
spi_software_miso_pin: PG7
driver_TPFD: 0
run_current: 1.0
interpolate: True
## Z1-axis on MOTOR3(left rear)
[stepper_z1]
step_pin: PB4
dir_pin: !PB3
enable_pin: !PB6
rotation_distance: 40 # Active pulley circumference mm (2GT-20T pulley 40, 2GT-16T pulley 32)
gear_ratio: 80:16 # reduction ratio
microsteps: 16 # microsteps
[tmc2240 stepper_z1] # TMC2209
cs_pin: PB5
driver_TPFD: 0
run_current: 1.0
interpolate: True
## Z2-axis on MOTOR4(right-rear)
[stepper_z2]
step_pin: PG13
dir_pin: PG12
enable_pin: !PG15
[tmc2240 stepper_z2]
cs_pin: PG14
driver_TPFD: 0
run_current: 1.0
interpolate: True
## Z3-axis on MOTOR5(right-front)
[stepper_z3]
step_pin: PG9
dir_pin: !PD7
enable_pin: !PG11
[tmc2240 stepper_z3]
cs_pin: PG10
driver_TPFD: 0
run_current: 1.0
interpolate: True
Thanks so much.
[stepper_z]
step_pin: PB8
dir_pin: PB7
enable_pin: !PE0
microsteps: 16
gear_ratio: 80:16
position_max: 340
position_min: -5.0
homing_speed: 10
[tmc2240 stepper_z]
cs_pin: PB9
driver_TPFD: 0
run_current: 1.0
interpolate: True
[stepper_z1]
step_pin: PB4
dir_pin: !PB3
enable_pin: !PB6
cs_pin: PB5
driver_TPFD: 0
run_current: 1.0
interpolate: True
[stepper_z2]
step_pin: PG13
dir_pin: PG12
enable_pin: !PG15
cs_pin: PG14
driver_TPFD: 0
run_current: 1.0
interpolate: True
[stepper_z3]
step_pin: PG9
dir_pin: !PD7
enable_pin: !PG11
cs_pin: PG10
driver_TPFD: 0
run_current: 1.0
interpolate: True
Thanks so much.
