Can't detect CB1 on my network (initial setup)
Shermoney
I'm setting up my first Vorin. It's the Formbot 2.4 350mm kit, and it comes with the BTT Manta M8P with CB1. I'm at the stage where I plug it in and detect the CB1's IP address, and nothing I do will detect it. I verified the wifi credentials in the config file, flashed the card several times, and even tried a separate card. IP scanners aren't showing it either, so I assume there's an issue with the board? The Wi-Fi antenna is attached, and everything is in one room along with the route. How can I troubleshoot this issue?
I did! I finally got access to it via Ethernet, but I ran into problems after that with flashing it, so I guess once I get through that, I will move on to wifi access so I dont have a cable stretched across my living room :cautious:
