- 2.4R2-350 - Formbot Kit/SB2040-Canbus/Octopus-Pro/TMC-5160T
- Galileo
I changed out the A/B belts on my 2.4R2-350, reset the TMC_Field SGT X/Y values, and after successfully homing All, the QGL no longer works? The printhead moves slightly off-center, accompanied by X/Y steppers making a high pitch noise, and then starts the initial (Z0 corner) check near the bed center. It then moves straight back and triggers they-stop as it's now completely out of position and I have to do an e-stop. Seems like there something not right with the Y-axis. However, homing and relative movement works fine (from Klipper menu, console, or touch screen), the QGL is just screwed up. Thanks in advance for any help!.....
