wonkothesane
- LDO 2.4 Rev D
- Clockwork 2
Hi
I am trying to set up my new LDO Voron 2.4 Rev D kit with the chaoticlab cnc tap v2, i have changed the wires to match the nitehawksb pin layout for the probe, however it always reads as triggered. the light changes when i lift it from blue to red, i have tried changing the printer.cfg to add "!" and "^" and "~" in various combinations to the pin gpio10 as per other threads but it doesnt make a difference. i have used a multimeter to check and i am getting 24v across the gnd and v, and when i check between gnd and s it registers a voltage change from 0 to around 4 (or reverse i cant remember which way round it was), it just seems like the board or klipper cant register this change. The board does seem to be working because my chamber thermistor which is connected does seem to be working and changes when it i make it warmer. I have also checked the continuity along the cable and from the cable to the soldered pin on the back of the board and they seem to be working. I have also tried changing the pin from gpio10 to gpio13 (from the x and y endtop port) but that seems to stay trigged on both states as well.
Any help you can provide will be greatly appreciated.
