I can understand a printer.cfg file describing port assignments on the Octopus board (which also runs Klipper).
What I don't understand is when additional MCU's running Klipper are brought into the mix,, how the final port gets controlled (shouldn't something change in the printer.cfg that points to a different MCU/port)
For example, it "looks" like there is no change to the Extruder motor section between a configuration with and without a CAN bus board.
How does Klipper in the Pi know that the extruder was moved from the Octopus board driver to the EBB 2209 board?
Please hlpe the light bulb turn on....
