EBB SB2209 CAN V1.0 (RP2040) + Voron Tap = Will not trigger Z endstop
Doogle
I am having quite the difficult time troubleshooting why Klipper will no longer trigger the z endstop no matter what I try... Tried shorting gpio21 directly to gnd and no change within Klipper. Also tried connecting to gpio22 and gpio6 but nothing will get Klipper to trigger the z endstop. Tried a fresh install of Klipper from scratch, using up-to-date install then reloading config, no change. Tried swapping with brand new spare SB2209 (RP2040) and a spare new optical tap module, but still cannot get z endstop to show triggered within Klipper.
Tried triple checking wiring, crimps, connections, config files, and I'm at a loss...
From printer.cfg:
[stepper_z]
[probe]
pin: EBBCan:gpio21
x_offset: 0
y_offset: 0
#z_offset: 0
speed: 10.0
samples: 3
samples_result: median
sample_retract_dist: 3.0
samples_tolerance: 0.006
samples_tolerance_retries: 3
activate_gcode:
{% set PROBE_TEMP = 150 %}
M109 S{ PROBE_TEMP }
{% else %}
{% endif %}
{% endif %}
  • config&logs.zip
    config&logs.zip
Did you manage to solve this? I seem to run into the exact same issue with my TAP and EBB RP2040. I've measured resistance over S and G and I would assume it's correct since it changes from 200 Ohm to 1k Ohm when triggered. However, I cannot read the state in Klipper for some reason.
I ended up working around the issue, getting 5V and Gnd from the EBB RP2040 and using one of the wires from my old drag chain, wrapped it around the CAN cable back to my Octopus v1.1 for the signal pin instead.
Thank you! I've re-crimped some shorter connections and now have tap fully connected to CANbus board again, only the CANbus cable and PTFE tube going out of toolhead. Looks much better now.
Hi!
for me ^gpio21 didnt work, however ^gpio22 did. Using gpio21 on the newer boards (mine is a week old and was ordered directly from bigtreetech) doesnt work with tap, with or without ^. Looking on your attached screenshot of the manual of ssb2209 rp2040 i assume it has changed in the past weeks (see attachment).
My config looks like this now:
pin: ^EBBCan:gpio22
My TAP therefore is wired to gpio22 and works fine now.
Did you wire the connection the same as in the can bus install guide? meaning the three wires in the "middle" if so can you share your config?
Hi!
pin: ^EBBCan:gpio22
THANKS YOU SO MUCH
For both of you: the board doesn't have a hardware pullup on gpio21 - so you need to list it as "pin: ^EBBCan:gpio21" in the config
You can also move it to gpio22 (still need the pullup ^ setting) - on my board the gpio21 pin was borked
Thank you this solved my issue as well!(y)
