First layer gaps after using Ellis' Print Tuning Guide (Voron 2.4 & SuperSlicer)
Jim_Jams_3rd
I been using Ellis PIF SuperSlicer profile and have followed all the steps in his tuning guide. My printer is now printing pretty fast, and the print quality is great.
However, I have a new issue with the first layer. There are always gaps between the layer lines even if I set my fist layer height a bit too low and really mush the plastic into the bed. It's weird beause the top layers are always really nice with no gaps at all.
  • 3D printer: Voron 2.4 with :Tap and Stealth Burner, Dragon standard flow hot end
  • Filament: ABS
  • Bed: textured PEI
I have attched my print settings as well.
I’m not sure what is causing this issue, does anyone have any ideas?
Thanks for the help
  • SuperSlicer_config_bundle.ini
I have a similar issue happening where my first layer is under extruding for no apparent reason. I have manually bumped extrusion up to 200% on the first layer and it lay's down pretty nice like that and as soon as layer 2 hits, I have to set it back to 100%. I can of course increase first layer extrusion in the slicer but I don't know why its doing this.
Yours looks to be the same. Try and find out what extrusion rate your first layer likes but printing a large flat sheet and playing the the rates. I will be curious to see what you find.
