Zephyrus67
- Voron 2.4 R2 300x300
- Clockwork 2
- Afterburner
Finally got my Voron 2.4 R2 finished yesterday.
After doing all the adjustments and settings I was ready for my first prints...
The first print came out perfectly and for the first time without using any add adhesion.
I printed ASA at 240/110 and just a tiny skirt around. No brim or glue or anything...and NO warping.
I printed 4 more prints with exactly same story.
Then at print no 6 out of a sudden I was not able to get the filament to stick to the bed. From not needing any adhesive to not getting it to stick at all....???
Instead it just curled the filament around the nozzle.
I tried doing the Z_ENDSTOP_CALIBRATE several time after a QGL but nothing helped...
I also tried raising the temperature to 250 but that did nothing eiher.
I was testing some extrusion with the toolhead raised to z=100 the filament came out fine in a straight clean line.
I did this several times between all the tests.
Now I have added a little very bad glue from a white glue stick to the bed and that seems to get it to stick. But the skirt is already gone. But I know that this glue stick is not very good.
In between the successful prints I cleaned the surface of the bed with IPA but I dont know if that can have caused the sudden constant failure.
Any ideas?
Finn
Any ideas?
Finn
