Question formbot kit issues in the homestretch
speaksoftly
i'm nearing fully-operational but have a couple things still tripping me up, using the 0.2r1 formbot kit with the dragon hotend.
1. all three of the fans on the extruder/hotend are nonworking. have checked continuity (ok) and plugged them all into working fan ports on the skr pico (the mcu fan works) and they do not spin up even with assistance. wondering if there are adjustments i can make to the skr pico firmware here, or if i just need to replace them
2. the ST display firmware, using the current klipper install, will not compile. the options are different than those in the voron documentation, and i've played around with them but have not been able to get them to work. the error is consistently that the binary becomes bigger than the allotted ROM space (i will follow up with exact error message tomorrow, along with version numbers) i'm not really sure which options i do need (i2c/spi etc) for this, either, and the documentation does not make that clear.
i've just kind of poked around at the forums here without seeing anything along these lines, but happy to be pointed to threads or guides.
