Gap after TAP installation
Stadi
Hello in the new forum, I'll start with a question. Since I converted to TAP, my SB has a gap between the CW2 and the cover.
At first I thought it was because all the parts were printed from PA12CF and the dimensions might therefore differ from the ABS parts. Now I've reprinted everything from ASA CF but the gap is still there. Anyone have an idea what could be the reason for this? I can't see anywhere that something is not mounted as it should be according to the instructions. Everything works great, so it's just an optical thing
Best regards
NoGuru
I know a lot of people have this issue but I do not. Maybe see if there is a spot that needs a little timing or filling.
antlestxp
Best regards
Did you ever find a solution?
Stadi
I haven't found out yet what the Reason is, just a guess. The two -part circuit board at SB is not the reason. When I open the front cover without screwing onto, there is no gap that only arises when the lower screws are put on. I suspect the problem lies in the fit of the pressure parts "Tap_Front_r2.stl" and "Tap_Upper_PCB_r2.stl". These have very little contact surface together. If there is only a slight deviation to 90 ° here, this affects much more on the top edge of the CW2. I printed these parts several times but it doesn't change. I first resigned myself to it because it is only an optical deficiency and does not affect the function.
