Question Heatsoak Macro
nopro
I'm still kinda new to Klipper and 3D printing so I thought I ask if my idea makes sense before trying to learn how to write macros.
I want to make a Heatsoak macro which automaticly detects when the thermal expansion has reached it's equilibrium and should be called from / before PRINT_START. My idea would look a bit like this:
Heat Nozzle
Heat Bed and Wait until Temperature is reached
Home all
Move to a corner of the Buildplate
Measure PROBE_ACCURACY
Wait 5 Min (maybe use delayed gcode to avoid freezing up the printer)
Compare the median of the last two measurements.
If the difference is below a treshold -> Start print
Else -> GOTO line 7
Is such a macro useful? Does something like this exist? If not, any help to write this is appreciated.
On a sidenote: There is usually a little blob / string of filament on the nozzle that oozed out. I usually wipe this off before Homing the axes as I'm afraid it will mess up my z-offset. Is there a more convenient solution?
Thank you very much for the help.
Here is my Preheat Macro, then I just add it to part of my Start_Print.
[gcode_macro PREHEAT]
gcode:
G90 #set absolute positioning
G28 #home all axis
## Move hotend a sufficent distance from heated bed for heat soak
G0 X175 Y175 Z50 F3600
M106 S255 #set parts fan to full speed, helps circulate chamber air
STATUS_HEATING
SET_HEATER_TEMPERATURE HEATER=heater_bed TARGET=105 #For ABS
STATUS_READY
As far as the blob on the nozzle, I have a scrub brush it runs to before the start of the print, purges, scrubs then starts.
gcode:
G28 #home all axis
STATUS_HEATING
STATUS_READY
Yet another Newb question: I've seen some comments about heat-soaking the printer for 30-60 minutes before starting the print. Do you find this necessary and if I included the PREHEAT macro in Startup how long will it preheat before allowing the rest of the Start_Print code to execute?
Depends on what material I am printing and the part itself. I have warped many parts in my years of printing so I can tell when one can be just sent and printed and when I need to heat soak the printer for a long time.
But in general, if I was to say print a medium size part in ASA, I would heatsoak for probably 30 minutes before starting the print. If I print anything in PLA I will just send it.
