Question help with artifacts on print
EricE555
2.4r2
Galileo
This is a 30mm voron test cube printing in hatchbox black PLA. All the other faces are perfect except this one. I can't figure out what is going on. I have printed this with ABS and 2 different PLA filaments. The artifacts did not appear in the ABS print but do appear in both PLA prints using different colors of PLA. Both the PLA prints used identical slicer settings so I am assuming this problem is slicer (orca) related.
1. I verified the seam is on the other side and goes up a corner (not random).
2. I dried the filament and tried again, same thing.
3. these are in the middle of a line so not related to Pressure Advance.
4. Some of the other faces print lines as across the whole face like this and had no artifacts.
I can't post all my slicer settings but I'll post back any setting that people think might be causing this
thanks in advance for your help.
Edit: so sorry, forgot the image. Its there now.
