Solved How to change the Ascend/Descend speed of bed mesh calibrate?
Laserbea4k43
How do change the Ascend/Descend speed of bed mesh calibrate when the toolhead has reached or is leaving the probe points?
Can I descend at a certain speed until it's reached a certain height before probing?
I'm using adaptive_bed_mesh.
fl-m0gIeaJMO28bp5bQxxufH5ax2JvG-rctVyAywwgBjI4RL_oM44OGRSUK-cAXErjX5cln-IhZXICsJ2mY5lerWRiO1W9QnJP64iT471U9IC0tDIiV_KUHxNcuav5qGBxgGXHuAb5Nq1DIA40DQoGQMNQabWSKWgoJnVfvwBOXg6Qp19q-2xX0sPDdeb24w2J39dCy3ZBLEwwrC83PWvRnHxC-2gfwprPe9gMPE0lTq-N_BmkKeowegLeam7V-jQ1vybdvSRbq2efhN6hfCy9g0E52uU5GliEjWq6qjxccNRfzoLNSPTubymGoCBqQWdJoAF6zHxPfr_8cMYg6HbiAVRb3namJhUFHS5r8ahZRoUV-LwSZRAYbidfEfknSjompLCEdlSwXLAIyEsZQysZ6_oW2V5yikUVqEKzY7B7iU62f4vnE61aDI3Q9YqIm5_rrchds6IWMVfZs4pw1g3GdoMNSQFWnWyz1g2Npf-9VBA9hIYV8HVu5eqtXnNlMd4BsfW4UbxKApNMViLYN6U2RNjmhst4KV74z6o4g5SEnZQnnnf9nIDkQn4rAAx8ScoYT0HI85Lh45L93xuzM594_RQIt5biEIciY3vMMGmzcqXTNxoJxGW82pSWEjqJXXEhnY5H5AxTU8Ovn85X4XPwnxeCq444KnuPTAZ-HXZqOc6f8bcQnkL9_FUM-l5QKHTsQAN8l-xnfwZNtUFw69wEcPUfPYw_2o8TaPG2FLyZn3G_hqaYWYsah8NtIxKCr3AQbuzpSbk_YtVTnQPTCRE8nOlyJJZWFXVSx7U-GNL5KbAl4INFdZxNDCaByNxRvv-9iDZozSquHTw5hd0n7SQqb46QSSPIjHXZt50cAmxAJEhFLvdg3vLkLmb8zjrOrxCvDaCSbr_lKu78uHy3Jex92BHqROy7dh_9jsIhxItVWezCtrItnT-qvzcYZEnV5Kq0cJztPS0wumnnRxDfOwBLM=w648-h864-no
NoGuru
I know why you want that but I think a better solution is to make sure and do the move at a lower height.
What I mean is if you have it raise to say 15mm above 0, make it 8mm.
NoGuru
Good advice, just need to know how to do that lol
I see. Under QGL in the printer config you will see something like,
Speed: 200000
horizontal_move_z: 10
retry_tolerance: 000000000000001
Max_adjust: 10
Don't use this config ^ but it should be there you can make your adjustment. Make sure and give yourself a little extra in case you heat the bed and it warps a little.
NoGuru
Just got home, I use TAP so this is fine for me but if you use Klicky try and get it 1 or 2 mm above the bed.
speed: 400
retries: 5
retry_tolerance: 0.0075
max_adjust: 10
Laserbea4k43
speed: 400
retries: 5
max_adjust: 10
I'm using Tap now also.
That does make sense, just limit how much movement there is on Z.
I wasn't sure exactly what horizontal_move_z did, even after reading the docs.
Thanks!
