First time using a PT1000, so I don't know what to expect. I have a v1 rapido plus plugged into an sb2040 v1 with the jumper on and my settings:
The thermistor is reading about 5C higher than I expect at room temp. It makes me a little nervous to start the heater though, because I don't know if it just reads slightly high, or if the problem is logarithmic and setting the temp to 240 will cause it to go up to 500 or something.
sensor_pin: SB2040v1:TH0
sensor_type: PT1000
pullup_resistor: 1000
