Question lack of filament after retraction
Zeid2110
As the title above. When I do the retraction, the print has a phenomenon of lacking plastic. I tried changing another heating head but it still doesn't work. I also did the temperature and retraction tests (0-1mm) and it was quite terrible even though before I tested the 100mm extrusion and it was very good. I'm very frustrated, I hope everyone can help. Thank you all.IMG_20250121_063849.jpgIMG_20250121_063902.jpgIMG_20250121_063952.jpgIMG_20250121_063958.jpgIMG_20250121_063947.jpg
Do you use firmware retraction or slicer set retraction?
If you use firmware retraction you must define the parameters in printer.cfg
