Firstly I'm glad that is working for you, as its very frustrating!! I have fitted heatsinks to my board, but with no change. Now I have been doing some further testing:Could be voodoo, but my problem with these errors went from 2 or 3 a week to once in 3 months when I replaced SB door/hatch part with a vented version (this one https://www.printables.com/model/907170-voron-clockwork2-cable-cover-with-ventholes-for-ld ). I was printing a lot of ASA & ASA-CF so 100-110 bed and 250-270 hotend temps. Had even bought a replacement high temp board to move to but haven’t had reason to switch out so it will go on a new printer next year. There’s another version with a 4010 fan on printables but a bit of wiring involved.
I have successfully printed ABS (4ish hr prints) I am conservative and these tend to be a slower feeds (100 -150mm/s 0.4 noz 0.2 layer height) but the bed is at 105°C and the nitehawk SB runs hotter.
I have successfully printed PLA (7ish hr print) but I slowed the speed to around 150mm/s (0.4 noz 0.2 layer height)
I have successfully printed with no filament at higher speeds 200-250mm/s (9ish hr print) multiple times both bed and hotend running at proper temps (60°C & 230°C)
HOWEVER every time I try to run this print with filament, then it fails usually 1-2hrs in. VERY FRUSTRATING!!! Wasted filament too.
I have checked and cleaned all electrical connections to the Nitehawk, and PI, I am running a high quality USB cable. Nothing has made a difference. BUT I am starting to think it could be to do with the umbilical cable itself (i have a 350 size machine and the umb. cable is very long); could it be that with higher volumetric flow from higher print speeds that the higher power draw from the hotend (possibly extruder too) is too much for the cable and causing a low voltage on the NH??
I'm wondering if I could make a temporary power cable to test this, or perhaps make my own umbilical cable?
