Mesh question
triafgg@
Hi
I am just building my first Voron 2 and am at the bed mesh stage, I have done a QGL and then a calibrate mesh. The variance is 0.89 but it looks like the bed is at 45 degrees but it is bolted down flat to the rails, is this normal?bed1.PNG
Looks like the rails need to be leveled out. Loosen the screws in the corner brackets to make your adjustments.
Yeah, check front left and rear right. Something is there throwing you off.
I tried adjusting the screws on the rails and the bed.
But I can't get a better result than this.
this and the cold plate
I would tighten down hard the one where it's red with other 3 looser, also you can pack up low bits a bit with aluminium tape, the sort used in heating/aircon ducting.
Also install KAMP, very easy to set up, very good instructions. Only levels the small area of the print. A small object wouldn't be affected by the high corner.
