Laserbea4k43
- Voron 2.4
- Clockwork 2
Took advantage of the ADXL on the NiteHawk and prettied my machine up to run tests.
Got some nice advice in the discord, but I figured feedback would be easier to track and reference in the future on the forums.
Images too large to upload. You can view here.
Also, What do I do with this information?
Thanks
- I ran my tests cold.
- AB belts measured with GT2 Belt Tension Meter @ 2.1
- Ran once on my wobbly table, made with 10-series extrusions and a top and bottom platform made of wood from the hardware store
- Ran second test on the floor
Tested on Table
// Shake&Tune version: v3.0.0-1-g56a5502
// Fitted shaper 'zv' frequency = 41.0 Hz (vibrations = 18.3%, smoothing ~= 0.093)
// To avoid too much smoothing with 'zv', suggested max_accel <= 6500 mm/sec^2
// Fitted shaper 'mzv' frequency = 28.0 Hz (vibrations = 2.5%, smoothing ~= 0.261)
// To avoid too much smoothing with 'mzv', suggested max_accel <= 2300 mm/sec^2
// Fitted shaper 'ei' frequency = 37.0 Hz (vibrations = 1.0%, smoothing ~= 0.238)
// To avoid too much smoothing with 'ei', suggested max_accel <= 2500 mm/sec^2
// Fitted shaper '2hump_ei' frequency = 42.6 Hz (vibrations = 0.0%, smoothing ~= 0.302)
// To avoid too much smoothing with '2hump_ei', suggested max_accel <= 1900 mm/sec^2
// Fitted shaper '3hump_ei' frequency = 52.4 Hz (vibrations = 0.0%, smoothing ~= 0.306)
// To avoid too much smoothing with '3hump_ei', suggested max_accel <= 1900 mm/sec^2
// -> Recommended shaper is EI @ 37.0 Hz (when using a square corner velocity of 5.0 and a damping ratio of 0.066)
// Peaks detected on the graph: 2 @ 29.8, 38.8 Hz (2 above effect threshold)
// shaper graphs created successfully!
// Cleaned output folder to keep only the last 3 results!
// Fitted shaper 'zv' frequency = 63.8 Hz (vibrations = 27.0%, smoothing ~= 0.043)
// To avoid too much smoothing with 'zv', suggested max_accel <= 15700 mm/sec^2
// Fitted shaper 'mzv' frequency = 42.6 Hz (vibrations = 0.9%, smoothing ~= 0.113)
// To avoid too much smoothing with 'mzv', suggested max_accel <= 5300 mm/sec^2
// Fitted shaper 'ei' frequency = 55.4 Hz (vibrations = 3.2%, smoothing ~= 0.106)
// To avoid too much smoothing with 'ei', suggested max_accel <= 5600 mm/sec^2
// Fitted shaper '2hump_ei' frequency = 63.8 Hz (vibrations = 0.0%, smoothing ~= 0.135)
// To avoid too much smoothing with '2hump_ei', suggested max_accel <= 4400 mm/sec^2
// Fitted shaper '3hump_ei' frequency = 78.6 Hz (vibrations = 0.0%, smoothing ~= 0.137)
// To avoid too much smoothing with '3hump_ei', suggested max_accel <= 4400 mm/sec^2
// -> Recommended shaper is MZV @ 42.6 Hz (when using a square corner velocity of 5.0 and a damping ratio of 0.052)
// Peaks detected on the graph: 3 @ 40.2, 58.1, 79.0 Hz (3 above effect threshold)
Tested on Floor
// Fitted shaper 'zv' frequency = 40.2 Hz (vibrations = 18.6%, smoothing ~= 0.099)
// To avoid too much smoothing with 'zv', suggested max_accel <= 6300 mm/sec^2
// Fitted shaper 'mzv' frequency = 28.0 Hz (vibrations = 3.0%, smoothing ~= 0.260)
// Fitted shaper 'ei' frequency = 37.4 Hz (vibrations = 1.6%, smoothing ~= 0.231)
// To avoid too much smoothing with 'ei', suggested max_accel <= 2600 mm/sec^2
// Fitted shaper '2hump_ei' frequency = 41.6 Hz (vibrations = 0.0%, smoothing ~= 0.314)
// To avoid too much smoothing with '2hump_ei', suggested max_accel <= 1800 mm/sec^2
// Fitted shaper '3hump_ei' frequency = 51.0 Hz (vibrations = 0.0%, smoothing ~= 0.318)
// To avoid too much smoothing with '3hump_ei', suggested max_accel <= 1800 mm/sec^2
// -> Recommended shaper is EI @ 37.4 Hz (when using a square corner velocity of 5.0 and a damping ratio of 0.088)
// Peaks detected on the graph: 1 @ 37.3 Hz (1 above effect threshold)
// Fitted shaper 'zv' frequency = 62.0 Hz (vibrations = 27.5%, smoothing ~= 0.045)
// To avoid too much smoothing with 'zv', suggested max_accel <= 14800 mm/sec^2
// Fitted shaper 'mzv' frequency = 42.0 Hz (vibrations = 1.2%, smoothing ~= 0.116)
// To avoid too much smoothing with 'mzv', suggested max_accel <= 5200 mm/sec^2
// Fitted shaper 'ei' frequency = 55.2 Hz (vibrations = 4.1%, smoothing ~= 0.107)
// Fitted shaper '2hump_ei' frequency = 61.4 Hz (vibrations = 0.0%, smoothing ~= 0.146)
// To avoid too much smoothing with '2hump_ei', suggested max_accel <= 4100 mm/sec^2
// Fitted shaper '3hump_ei' frequency = 76.2 Hz (vibrations = 0.0%, smoothing ~= 0.146)
// To avoid too much smoothing with '3hump_ei', suggested max_accel <= 4100 mm/sec^2
// -> Recommended shaper is MZV @ 42.0 Hz (when using a square corner velocity of 5.0 and a damping ratio of 0.050)
// Peaks detected on the graph: 4 @ 40.3, 56.7, 70.1, 79.1 Hz (4 above effect threshold)
Thanks
