My Sensorless Homing script
irii
Hello,
I like to share my sensorless homing config script which allows run-current reduction with the same homing behaviour when using safe_z_home.
This has the big advantage, that separate axis homing is possible. Usually if X is requested all axis are marked as homed (which is not true). This script tries to fix this issue.
This script is based on the default senorless config from the voron documentation.
As always use at your own risk!
BR, irii
