elettronik
Hello, this is my build log for my voron 2.4.
It started with a LDO kit, then during the build some variations were added.
Documentation
Official
LDO
02/03/2024
Unboxing
Let's start with the right foot, opening the box on the wrong side
The frame
Probably the most important part
09/03/2024
Adding bed support
After cleaning the rails, add Z rails on the wrong side
17/03/2024
Fix rails position and add bottom panel and DIN rails
Z Axis
23/03/2024
Z motor pulleys...
.. and relative motor assembly
Mount them on the body
30/03/2024
Z idlers
Mounted
Documentation
Official
LDO
- https://docs.ldomotors.com/en/voron/voron2/build-faq
- https://docs.ldomotors.com/en/voron/voron2/wiring_guide_rev_c
02/03/2024
Unboxing
The frame
09/03/2024
Adding bed support
17/03/2024
Z Axis
23/03/2024
Z motor pulleys...
30/03/2024
Z idlers
Mounted
