I've used the V5 and just recently built the V6. I kinda like the V6 since you don't have to cut up the 5015 blowers.
The only thing I really don't like about the V6 is the lid (Jalousie), but there a remix on printable that replaces that with one you can bolt in.
After printing 6 attempts of the Jalousie, I gave up and just designed a solid piece to fit. It worked perfectly and snaps in, no leaks and is easy to remove. I also use two filters--V6 and a modified external filter in the rear of the 'stock' filter listed in the STLs for V2, using a modification downloaded from 'Printables'. Sorry I don't have the link handy, It uses a printed flow thru box with the same filter media of the Nevermore, and just slides in to the filter housing. I feel the 2.4 needs more than one filter with ABS. With two filters, there is almost no smell now.
