Hi, what kind of probe it is? If it's inductive, can you provide exact model number? To test it, put some metal object under it, like wrench, and run QUERY_ENDSTOPS.
Can you also post whole Z Endstop, QGL and Probe section of the config?
I was working through similar error msgs last night while trying to get my V2.42 with a Biqu Microprobe set up. For me the answer was, partially at least, that my Z endstop stood up about 10 mm above the bed, so my -8 wasn't enough for the min. I changed it to -18 temporarily and it worked.
Most commonly this happens when your bed or gantry is so out of whack before QGL that is exceeds tolerances set in configuration. Usually happens when back of the gantry sags after motors are turned off.
