Probably another noob issue but I need help. I've had everything running fine without issue until one day (about 6 months ago) the hot end crashed into my bed breaking the TAP mount. Since then I've gotten the TAP mount reprinted and everything is as it was except my optical sensor seems to not work (no LED lights active, can't get it to trigger). I can trigger the optotap v2.4.1 led if I manually power the 24v and ground connections with a spliced cable from a usb adapter so I know it works (blue led turns on). I don't recall changing anything in my printer.cfg file and I've checked continuity from the printer mainboard to the stealthburner PCB for the 24v, probe signal (connected to PG15 on my bigtreetech octopus board), and ground wires to my optotap pcb. The ground and 24v are fine all the way up to the optotap board connections but the probe signal is only showing continuity up until the bat85 diode on the steathburner pcb. Is that normal? I've tried a different stealthburner pbc, two different optotap probes and the result is the same, no power or triggering of the probe sensor. I an manually trigger the red led on the optotap if I manually connect a probe wire from the the BTT octopus mainboard to the optotap signal connection on the optotap pcb (red led turns on but does not trigger endstop). I don't understand why my optotap sensor is not working which is likely the cause of my initial crash into the bed as it won't trigger, as if its not even there. Help please! Printer.cfg file attached for review.
