snow 3dp
ok i know something absolutely stupid has to be going on here! i had everything working and then i copied this section to notepad++ and deleted it from my config to try something and then put my config back to the way it was and this happens. any help would be much appreciated.
voron 2.4 r2
tap
manta m8p v2
sb2209 rp2040
# Probe
[probe]
## Inductive Probe
## This probe is not used for Z height, only Quad Gantry Leveling
## NPN and PNP proximity switch types can be set by jumper
pin: ^EBBCan:gpio22 #PF1 #M4-STOP
x_offset: 0
y_offset: 0
z_offset: 0
speed: 10.0
samples: 3
samples_result: median
sample_retract_dist: 3.0
samples_tolerance: 0.006
samples_tolerance_retries: 3
activate_gcode:
{% set PROBE_TEMP = 150 %}
{% set MAX_TEMP = PROBE_TEMP + 5 %}
{% set ACTUAL_TEMP = printer.extruder.temperature %}
{% set TARGET_TEMP = printer.extruder.target %}
{% if TARGET_TEMP > PROBE_TEMP %}
{ action_respond_info('Extruder temperature target of %.1fC is too high, lowering to %.1fC' % (TARGET_TEMP, PROBE_TEMP)) }
M109 S{ PROBE_TEMP }
{% else %}
# Temperature target is already low enough, but nozzle may still be too hot.
{% if ACTUAL_TEMP > MAX_TEMP %}
{ action_respond_info('Extruder temperature %.1fC is still too high, waiting until below %.1fC' % (ACTUAL_TEMP, MAX_TEMP)) }
TEMPERATURE_WAIT SENSOR=extruder MAXIMUM={ MAX_TEMP }
{% endif %}
{% endif %}
voron 2.4 r2
tap
manta m8p v2
sb2209 rp2040
# Probe
[probe]
## Inductive Probe
x_offset: 0
y_offset: 0
z_offset: 0
speed: 10.0
samples: 3
activate_gcode:
{% else %}
{% endif %}
{% endif %}
