persistent config error
My search has come up empty and I'm running out of ideas. I keep getting an error:
Option 'pwm' is not valid in section 'controller_fan controller_fan'
My fan config is below. I'm running Klipper on Octopus with an EBB SB 2209/2240 Canbus. I have yet to get this working, still trying to get all the errors out of the config file.
I've tried adding pwn: true or false but not sure how to make the program happy.
# Fan Control
## Print Cooling Fan - FAN0
[fan]
pin: PA8
kick_start_time: 0.5
## Depending on your fan, you may need to increase this value
## if your fan will not start. Can change cycle_time (increase)
## if your fan is not able to slow down effectively
off_below: 0.10
## Hotend Fan - FAN1
[heater_fan hotend_fan]
pin: PE5
max_power: 1.0
heater: extruder
heater_temp: 50.0
## If you are experiencing back flow, you can reduce fan_speed
#fan_speed: 1.0
## Controller fan - FAN2
[controller_fan controller_fan]
pin: PD12
heater: heater_bed
## Exhaust fan - FAN3
#[heater_fan exhaust_fan]
#pin: PD13
#max_power: 1.0
#shutdown_speed: 0.0
#kick_start_time: 5.0
#heater: heater_bed
#heater_temp: 60
#fan_speed: 1.0
Any help would be appreciated.
Joel
Post your entire config, not just the snippet. Since everything past the controller fan section is commented out in your post, I wouldn't be surprised to find the problem is hiding somewhere even farther down...
EEEK,
OK, here it is. As of yet, I haven't gotten this thing to work, still trying to get config to load.
Thanks for your help.
Joel
  • Configvoron.pdf
You commented out "[output_pin caselight]" , but not the rest of that section. So lacking a section header, all those settings down there think they're a continuation of the last section header before that....your controller fan.
