Spider 3.0 no motor movement [FIXED]
grillchen
DIY 2.4
EDIT: Connector on the side next to the X driver was missing (see https://github.com/FYSETC/FYSETC-SPIDER/blob/main/hardware/V3.0/VORON2.4R2_SPIDER_V30_WIRING.pdf)
I had no jumper at hand but realized a terminal plug fits quite well. i used a saw to make it a little bit shorter to make sure the pins have a connection since they are rather short. And a cable i got out of a cold appliance cable. Since each driver can take up to ~2.5A i assume up to 20A can be pulled throug the cable.... So dont use a thin cable please
Hi,
my Spider 2.3 broke and so I try to replace it with a 3.0.
I assume i did something wrong with the jumpers i set. I use a BL Touch and no can bus btw. I do have jumpers on:
VP - 5V
BT0- G
DC5V- The middle next to it
below the TMC2208 like this picture (https://github.com/FYSETC/FYSETC-SPIDER/blob/main/hardware/V3.0/VORON2.4R2_SPIDER_V30_WIRING.pdf) (the above jumpers are also in the pic) i also tested having 4 jumpers in the top row for 4988 like drivers. I use tmc2208 1.2 drivers in standalone mode (maybe uart later but first i wanna get it to work again.
When i restart everything the FLASH Leds also shines bright (just like the rest). Pressing bt0 turns it off and klipper doesnt recognize the board. Before it connects and temperature is shown correctly.
Attached my config
What am I missing?
Best regards
[include mainsail.cfg]
[include timelapse.cfg]
[printer]
kinematics: corexy
max_velocity: 300
max_accel: 3000 #Max 4000
max_z_velocity: 15 #Max 15 for 12V TMC Drivers, can increase for 24V
max_z_accel: 350
square_corner_velocity: 5.0
# X/Y Stepper Settings
[stepper_x]
## Connected to X-MOT (B Motor)
step_pin: PE11
dir_pin: PE10
enable_pin: PE9
rotation_distance: 240#####################################################################
# LED Control
#[output_pin caselight ]
## Chamber Lighting - In 5V-RGB Position
#pin: PD3
#pwm: true
#shutdown_value: 0
#value:100
#cycle_time: 0.01
microsteps: 32
full_steps_per_rotation:200 #set to 400 for 0.9 degree stepper
endstop_pin: PB14
position_min: 0
homing_speed: 80
## Uncomment below for 250mm build
position_endstop: 0
position_max: 250
[stepper_y]
## Connected to Y-MOT (A Motor)
step_pin: PD8
dir_pin: PB12
enable_pin: !PD9
microsteps: 32
endstop_pin: PB13
position_min: 0
homing_speed: 80
## Uncomment for 250mm build
position_endstop: 250
position_max: 250
## Uncomment for 300mm build
#position_endstop: 300
#position_max: 300
## Uncomment for 350mm build
#position_endstop: 350
#position_max: 350
#homing_retract_dist: 5homing_positive_dir: true
# Z Stepper Settings
#[safe_z_home]
#home_xy_position: 100, 100 # Change coordinates to the center of your print bed
#speed: 50
#z_hop: 10 # Move up 10mm
#z_hop_speed: 5
## In Z-MOT Position
## Z0 Stepper - Front Left
[stepper_z]
step_pin: PD14
dir_pin: !PD13
enable_pin: !PD15
rotation_distance: 16
#gear_ratio: 5:1
microsteps: 32
position_max: 240
position_min: -5
homing_speed: 2
homing_retract_dist: 3
[stepper_z1]
step_pin: PD5
dir_pin: !PD6
enable_pin: !PD4
gear_ratio: 5:1
microsteps: 32
#[stepper_z2]
#step_pin: PE6 # PE5 PE6 PC13
#dir_pin: !PC13
#enable_pin: !PE5
#rotation_distance: 32
##gear_ratio: 1:5
#microsteps: 32
#[stepper_z3]
#step_pin: PE2
#dir_pin: !PE4
#enable_pin: !PE3
#rotation_distance: 16
##gear_ratio: 5:1
#microsteps: 32
## In E0-MOT Position
[extruder]
step_pin: PE1
dir_pin: PE0
enable_pin: !PC5
## Update value below when you perform extruder calibration
## If you ask for 100mm of filament, but in reality it is 98mm:
## rotation_distance = <previous_rotation_distance> * <actual_extrude_distance> / 100
## 22.6789511 is a good starting point
rotation_distance: 22.6789511 #Bondtech 5mm Drive Gears
## Update Gear Ratio depending on your Extruder Type
## Use 50:17 for Afterburner/Clockwork (BMG Gear Ratio)
## Use 80:20 for M4, M3.1
gear_ratio: 50:17 #BMG Gear Ratio
microsteps: 16
full_steps_per_rotation: 200 #200 for 1.8 degree, 400 for 0.9 degree
nozzle_diameter: 0.400
filament_diameter: 1.75
## In E0 OUT Position
heater_pin: PB15
## Validate the following thermistor type to make sure it is correct
sensor_type: Generic 3950#ATC Semitec 104GT-2
sensor_pin: PC0 # TE0 Position
min_temp: -250
max_temp: 270
max_power: 1.0
min_extrude_temp: 170
control = pid
pid_kp = 26.213
pid_ki = 1.304
pid_kd = 131.721
## Try to keep pressure_advance below 1.0
pressure_advance: 0.05
## Default is 0.040, leave stock
pressure_advance_smooth_time: 0.040
# Bed Heater
[heater_bed]
## SSR Pin - In BED OUT position
heater_pin: PC8 # changed from pb4
sensor_type: Generic 3950 # NTC 100K MGB18-104F39050L32
## Uncomment below for SpiderVersion 1.x
#sensor_pin: PC3 # TB Position
## Uncomment below for SpiderVersion 2.2
sensor_pin: PB0 # TB Position
## Adjust Max Power so your heater doesn't warp your bed
max_power: 0.6
min_temp: -250
max_temp: 120
control: pid
pid_kp: 58.437
pid_ki: 2.347
pid_kd: 363.769
# Bltouch
[bltouch]
## Bltouch - If you use this section , please comment the [probe] section
## More infomation at : https://www.klipper3d.org/BLTouch.html
## This bltouch is not used for Z height, only Quad Gantry Leveling
## In Z+ Position
sensor_pin: ^PA0
# In Y+ Position
control_pin: PA2
#x_offset: 0
#y_offset: 25.0
z_offset: 0
#speed: 10.0
#samples: 3
#samples_result: median
#sample_retract_dist: 3.0
#samples_tolerance: 0.006
#samples_tolerance_retries: 3
# Fan Control
[heater_fan hotend_fan]
## Hotend Fan - FAN0 Connector
#pin: PB0
pin: PA13
max_power: 1.0
kick_start_time: 0.5
heater: extruder
heater_temp: 50.0
## If you are experiencing back flow, you can reduce fan_speed
#fan_speed: 1.0
[fan]
## Print Cooling Fan - FAN1 Connector
#pin: PB1
pin: PA14
max_power: 0.4
## Depending on your fan, you may need to increase this value
## if your fan will not start. Can change cycle_time (increase)
## if your fan is not able to slow down effectively
off_below: 0.10
[heater_fan controller_fan]
## Controller fan - FAN2 Connector
pin: PB2
heater: heater_bed
heater_temp: 45.0
[idle_timeout]
timeout: 1800
[safe_z_home]
## XY Location of the Z Endstop Switch
## Update -100,-100 to the XY coordinates of your endstop pin
## (such as 157,305) after going through Z Endstop Pin
## Location Definition step.
home_xy_position:100,100
speed:50
z_hop:5
z_hop_speed: 2
got a clue. the 24v plug at the side next to the X driver is not there. probably error on my side. gotta think of a replacement. to my understanding the driver get no power at all rn
