Upperbottom
I need some help to start debugging my printer with some VFA:s
After one year it was time to upgrade my printer, the quality was bad, terrible VFA mostly wood-grain and I couldn't fix it.
After the teardown a part of the problem was obvious: I had too much gear-mesh in the past in the CW2 and ground down my main-gear, so even adjusting that would not help since the. gear was ground down on one side.
To prevent future cable-beaks and get a cleaner build I went Canbus and a new CW2 with helical gear.
After basic tests and doing some dial-ins (e-steps, first layer, pressure-advance, extrusion multiplier and input shaper) I printed a "mihaid-wedge" to see if i still had VFA.
Good news: no more woodgrain!
Bad news: the VFA in the X-axis front facing wall is gone, in the y-axis I got a diagnoal wavy pattern towards the back of the print which leads to artefacts in the back-facing wall of the wedge
(se image below the front is facing towards the lightsource) .
The error is even visible when printing a cylinder in vase-mode (print parameters in the end)
Front: Nice
Back: not so much
What I think are possible causes:
1. Gantry racked
2. Belts uneven
3. Insufficient cooling
4. bad/insufficiently lubed linear rails
Parameters:
Orca Slicer
PLA
.4 nozzle
210 degrees print temp
60 degrees bed temp
print speed: outer wall 120mm/s*, 3000mm/s2 accel
open printer
*due to layer time limits the wedge first printed at about 7 mm/s but i manually upped the speed 600% so about 56mm/s, the cylinder printed at roughly 108mm/s after reducing the layer time from 8 to 1 second
Front: Nice
Back: not so much
1. Gantry racked
2. Belts uneven
Parameters:
Orca Slicer
PLA
.4 nozzle
60 degrees bed temp
open printer
