Solved Save & Restart No longer works
Laserbea4k43
Hello,
When editing my config files and needing to restart klipper or firmware, klipper seems not to be able to connect.
I always have to restart my pi in order to get things working again.
I've attached logs, if anyone can help me out, thanks.
  • klippy (1).log
Laserbea4k43
Thanks guys,
I didn't realize i'd gotten replies!
It turns out I accidentally commented out a line in the printer.cfg
Laserbea4k43
Actually it didn't work.
I thought it did, I was wrong.
I'm using an RPi 4 B and BTT Octopus Pro with Fluidd
egar
I've been having a simiilar issue for a few weeks. I don't remember the exact message, but it is something like "can't connect to MCU". The issue doesn't happen every time I save and restart, but it does happen the majority of the time. The only way to restore operations is a full restart of the Raspberry PI. I have a suspicion that a recent update to Moonraker or Klipper may be part of the problem. I've searched Discord for the error message and there seem to be a few people there with similar issues -- mostly beginning in December.
Laserbea4k43
In the voron discord, the first pinned message in #klipper solved the problem for me(thanks @Dragonkitty)
sudo systemctl disable ModemManager.service then reboot the pi.
Apparently, there are conflicts with klipperScreen.
I’ve been hitting save & restart for fun 😁
egar
That fixed my issues! Thanks again!
BTW, on the KlipperScreen GitHub, they are now recommending using command sudo systemctl mask ModemManager.service as a more "persistent" solution.
Proabably a little bit beyond my understanding, but I'm guessing the masking, which seems to do a redirect, will prohibit the re-enablement of the service during updates/upgrades.
120decibell
Administrator
Staff member
Moderator
Voron Owner
Correct. It will prevent re-enabling by another process or update.
