- Voron 2.4 R2 350
- Clockwork 2
Hello community!
I am a new one here, so i hope i did not break any rules with this thread (searched before creating a new one). So my problem is that when i try to test and pull up toolhead with CNC Voron Tap v2 and check Endstops section, nothing works, always shows me OPEN, but led color switched from blue to red.
All connections were build regarding the official documentation
This is my config file parts:
If you know how to solve it, I will be very grateful. Thank you.
[probe]
pin: EBBCan: PB9
x_offset: 0
y_offset: 0
z_offset: 0
speed: 5.0
samples: 2
samples_result: median
sample_retract_dist: 3.0
samples_tolerance: 0.006
samples_tolerance_retries: 4
activate_gcode:
{% set PROBE_TEMP = 150 %}
M109 S{ PROBE_TEMP }
{% else %}
{% endif %}
{% endif %}
[stepper_z]
step_pin: PF11
dir_pin: !PG3
enable_pin: !PG5
rotation_distance: 40
gear_ratio: 80:16
microsteps: 32
