Some questions about my Voron 2.4 Siboor configuration
Do you take just the power from there, or do you use signal pin as well? Either way, you can take a look at additional LED controllers. For example Klipper Expander board has RGB port and installs as another MCU. Or look at WLED controller, Moonraker has support for WLED.
The RGB output on the board is organized through FAN connectors. But I only need one signal pin, I will take power from the additional power supply.
Or do I not understand something?
It is easier then to transfer the head to a CAN connection, thus freeing the control pin for the RGBW on the board
That's also a solution, if you have patience to set up CAN.
