almightyjes
- 2.4 r2 fysetc
- Clockwork 1
- Afterburner
hi,
my stepper X / motor B has locked up.
i suspect i messed up when i was installing klicky probe, i misread the toolhead pcb and had one of the wires in the wrong pin, tough i noticed the mistake somewhat immediately after powering on the printer, so less then 1 min.
after correcting the wire, i kept going and when i got to the point where i had to home so i could find the mount location, it just went BRRR (rubbing belt on motor B wheel(?)), after 1-2 hours i figured out it was the motor thats locked up and not a config problem, did a total of 4 homing attempts, hopefully that didnt mess up more.
is there anything i can do, or is there a way to check/test driver (tmc2209) and motor to see which is bad (or mcu spider v2.3), or is it just buying a new stepper motor and driver, printer is about 48 hours old, i see this as a learning experience, and im still smilling![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
i´ll gladly share any logs or anything if it can help you to help me![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
thanks
thanks
