Does your bed move up and down if you push down on it with 600-700g?I've seen some documentain that TAP was available for 2.4 and trident. It should be possible also with Voron Switchwire right?
If yes, TAP is not for you.
Hence 1.8, Legacy and Switchwire are not compatible.
Can you please explain what mouting plate you used to make the belt mounting work on the tap with SwitchWire? As the belts are underneath the X-carriage on SwitchWire, the std belt mounting plate of Tap cannot be used...Yes, I added stealthburner and tap to my switchwire. It worked fine.
The part that mounts the toolhead to the rail will need to be designed to support both TAP and hold the belts.Can you please explain what mouting plate you used to make the belt mounting work on the tap with SwitchWire? As the belts are underneath the X-carriage on SwitchWire, the std belt mounting plate of Tap cannot be used...
Entirely possible to hard mount the printer bed. That's the whole point of TAP - to let klipper figure out the bed mesh for you so you don't need to level the table. Just get it so sub 1mm across the whole plate and you are good to go.I had this experience of putting the TAP on my SW, there is a reason that I ignored why it is only compatible with the 2.4 and trident, because the table has to be extremely fixed and like the SW the support is only in the center, after the nozzle hitting the table causes a certain variation in the reading and renders the TAP function useless
