jeremytodd1
I've had a LDO 350mm Voron 2.4 that I've had for several months now. I've had good luck with it so far. I decided to recently change out the x-axis rail to a Honeybadger x axis rail because the LDO rail I had had a little bit of play in it.
After doing that though, I'm seeing some odd results with my Input Shaper though.
My setup:
Room temperature:
Things I've looked at:
My setup:
- LDO Voron 2.4 - 350mm
- CW2/Stealthburner
- Tap
- Ebb36
- TI Backers
Room temperature:
- X axis:
- Y axis:
- X axis:
- Y axis:
- Verified all screws (gantry related and in the toolhead/Tap) are tight
- A/B belts are both tensioned to 120hz, give or take 5hz. This was done very recently right after installing the Honeybadger x axis rail
