USB PCB cam with LED, using the LED
stevensryanw
Just got this webcam working through Crowsnest https://www.ebay.com/itm/3946329935...-ba20-aeca982a68af|iid:1|vlpname:vlp_homepage, wondering if anyone has used it before and can help me figure out how to use the led flash, and hopefully add a toggle to mainsail
Here is my crowsnest.log:
Armbian 23.8.1 bullseye
[10/07/23 23:39:32] crowsnest: Host Info: Kernel: Linux 5.10.85-sunxi64 aarch64
[10/07/23 23:39:32] crowsnest: Host Info: Available CPU Cores: 4
[10/07/23 23:39:32] crowsnest: Host Info: Available Memory: 1008252 kB
[10/07/23 23:39:32] crowsnest: Host Info: Diskspace (avail. / total): 25G / 29G
[10/07/23 23:39:32] crowsnest: INFO: Checking Dependencies
[10/07/23 23:39:33] crowsnest: Dependency: 'crudini' found in /usr/bin/crudini.
[10/07/23 23:39:33] crowsnest: Dependency: 'find' found in /usr/bin/find.
[10/07/23 23:39:33] crowsnest: Dependency: 'xargs' found in /usr/bin/xargs.
[10/07/23 23:39:33] crowsnest: Dependency: 'ustreamer' found in bin/ustreamer/ustreamer.
[10/07/23 23:39:33] crowsnest: Version Control: ustreamer is up to date. (v5.42)
[10/07/23 23:39:33] crowsnest: INFO: Print Configfile: '/home/fly/printer_data/config/crowsnest.conf'
[10/07/23 23:39:33] crowsnest: [crowsnest]
[10/07/23 23:39:33] crowsnest: log_path: /home/fly/printer_data/logs/crowsnest.log
[10/07/23 23:39:33] crowsnest: log_level: verbose
[10/07/23 23:39:33] crowsnest: delete_log: false
[10/07/23 23:39:33] crowsnest: no_proxy: false
[10/07/23 23:39:33] crowsnest: [cam 1]
[10/07/23 23:39:33] crowsnest: mode: ustreamer
[10/07/23 23:39:33] crowsnest: enable_rtsp: false
[10/07/23 23:39:33] crowsnest: rtsp_port: 8554
[10/07/23 23:39:33] crowsnest: port: 8080
[10/07/23 23:39:33] crowsnest: device: /dev/video1
[10/07/23 23:39:33] crowsnest: resolution: 1280x720
[10/07/23 23:39:33] crowsnest: max_fps: 10
[10/07/23 23:39:33] crowsnest: INFO: Detect available Devices
[10/07/23 23:39:33] crowsnest: INFO: Found 1 total available Device(s)
[10/07/23 23:39:33] crowsnest: INFO: Found 1 available v4l2 (UVC) camera(s)
[10/07/23 23:39:34] crowsnest: /dev/v4l/by-id/usb-Vimicro_Corp._HBVCAM_FHD_CAMERA-video-index0 -> /dev/video1
[10/07/23 23:39:34] crowsnest: Supported Formats:
[10/07/23 23:39:34] crowsnest: [0]: 'MJPG' (Motion-JPEG, compressed)
[10/07/23 23:39:34] crowsnest: Size: Discrete 640x480
[10/07/23 23:39:34] crowsnest: Interval: Discrete 0.033s (30.000 fps)
[10/07/23 23:39:34] crowsnest: Size: Discrete 320x240
[10/07/23 23:39:34] crowsnest: Size: Discrete 2048x1536
[10/07/23 23:39:34] crowsnest: Interval: Discrete 0.067s (15.000 fps)
[10/07/23 23:39:34] crowsnest: Size: Discrete 2592x1944
[10/07/23 23:39:34] crowsnest: Size: Discrete 1920x1080
[10/07/23 23:39:34] crowsnest: Size: Discrete 1600x1200
[10/07/23 23:39:34] crowsnest: Size: Discrete 1280x960
[10/07/23 23:39:34] crowsnest: Size: Discrete 1280x720
[10/07/23 23:39:34] crowsnest: [1]: 'YUYV' (YUYV 4:2:2)
[10/07/23 23:39:34] crowsnest: Interval: Discrete 0.500s (2.000 fps)
[10/07/23 23:39:34] crowsnest: Interval: Discrete 0.167s (6.000 fps)
[10/07/23 23:39:34] crowsnest: Interval: Discrete 0.100s (10.000 fps)
[10/07/23 23:39:34] crowsnest: Supported Controls:
[10/07/23 23:39:34] crowsnest: brightness 0x00980900 (int) : min=-255 max=255 step=1 default=0 value=0
[10/07/23 23:39:34] crowsnest: contrast 0x00980901 (int) : min=0 max=30 step=1 default=15 value=15
[10/07/23 23:39:34] crowsnest: saturation 0x00980902 (int) : min=0 max=127 step=1 default=40 value=40
[10/07/23 23:39:34] crowsnest: hue 0x00980903 (int) : min=-180 max=180 step=1 default=0 value=0
[10/07/23 23:39:34] crowsnest: white_balance_temperature_auto 0x0098090c (bool) : default=1 value=1
[10/07/23 23:39:34] crowsnest: gamma 0x00980910 (int) : min=20 max=250 step=10 default=100 value=100
[10/07/23 23:39:34] crowsnest: power_line_frequency 0x00980918 (menu) : min=0 max=2 default=1 value=1
[10/07/23 23:39:34] crowsnest: 0: Disabled
[10/07/23 23:39:34] crowsnest: 1: 50 Hz
[10/07/23 23:39:34] crowsnest: 2: 60 Hz
[10/07/23 23:39:34] crowsnest: white_balance_temperature 0x0098091a (int) : min=2800 max=6500 step=1 default=5000 value=5000 flags=inactive
[10/07/23 23:39:34] crowsnest: sharpness 0x0098091b (int) : min=0 max=127 step=1 default=30 value=30
[10/07/23 23:39:34] crowsnest: exposure_auto 0x009a0901 (menu) : min=0 max=3 default=0 value=0
[10/07/23 23:39:34] crowsnest: 1: Manual Mode
[10/07/23 23:39:34] crowsnest: 3: Aperture Priority Mode
[10/07/23 23:39:34] crowsnest: exposure_absolute 0x009a0902 (int) : min=39 max=5000 step=1 default=333 value=333 flags=inactive
[10/07/23 23:39:34] crowsnest: exposure_auto_priority 0x009a0903 (bool) : default=0 value=0
[10/07/23 23:39:34] crowsnest: focus_absolute 0x009a090a (int) : min=0 max=831 step=1 default=0 value=0 flags=inactive
[10/07/23 23:39:34] crowsnest: Try to start configured Cams / Services...
[10/08/23 18:15:23] crowsnest: INFO: Configuration of Section [cam 1] looks good. Continue ...
[10/08/23 18:15:25] crowsnest: V4L2 Control: No parameters set for [cam 1]. Skipped.
[10/08/23 18:15:30] crowsnest: Starting ustreamer with Device /dev/video1 ...
[10/08/23 18:15:32] crowsnest: ... Done!
Hi guy i have exactly the same isue, i don't find how to manually set on/off the led from this OV5640 cam.
