V2.4 will not start print.
husa550
Voron 2.4
Clockwork 1
Afterburner
I have a Formbot V2.4 R1 and it have worked really good!
Wanted to test the adaptive mesh and purge and installed that.
Things worked pretty fine untill they did not!
When i start a print i preheat bed to 110C and nozzle to 150C manualy first so it will heat the chamber.
Then start the print, but now i got this error:
Error evaluating 'gcode_macro PRINT_START:gcode': UndefinedError: 'dict object' has no attribute 'BED'
Is this a config problem or is it something wrong with slicersettings?
I am using SuperSlicer 2.4.58.5
husa550
Most likely it is something going on with the slicer, older files that i already have printed before seems to work.
shiftingtech
Staff member
Moderator
Voron Owner
sounds like a problem with the start code on the slicer side. is it passing a BED=...something parameter?
(it should be)
